A balloon biking attempt
I decided to try ‘balloonbiking’ and got some Schwalbe Big Apples for my Pinnacle Arkose, which is supposed to be able to take up to a 700x47C tyre. The Big Apples are classed as a 700x50.
The font fitted fine. But the rear tyre was too big and ended up wedged against the front derailleur mech. I had a fiddle but ended up screwing up the settings, so that meant a trip to my local Evans (whose workshop is open on a Sunday).
The young (and I must say rather cute) mechanic did his best but without replacing everything- including the levers - it’s not going to be possible to run the tyre on the rear. He measured it and it was actually 700x48 - so should really have fitted. He reckons that although the bike is advertised as being able take up to 47, the rear can only really take up to a 42.
I’m going to keep the Big Apple on the front and I’ve got a Schwalbe Marathon Plus Tour 622-42 on order for the rear.
I’ll post some piccies of the Frankenbike when I’ve got the rear tyre sorted.
Fiat justitia - ruat caelum
- The Real Ravenhurst
Re: A balloon biking attempt
I've never tried them, they strike me as being rather 'dragy' with such a large footprint on the road.
So the changes have been made. I've gone from a Marathon Plus Tour 37-622 front and rear to a Schwalbe Big Apple 50-622 on the front and a Marathon Plus 42-622 on the rear. It'll be interesting to see if there's any change on the comfort and rolling resistance side of things.
I'll try it out on the ride to Pilates this evening.
Photos later.
Photos later.
I'd be interested in how you get on. I bought an Arkose earlier this year - great bike, but the 37c tyres (WTB Riddlers) are a touch narrow for rocky off-road use, and I need to run higher pressures than I'd like to avoid pinch flats, which reduces grip. Ideally I'd run 45c and convert to tubeless.
ransos wrote: ↑5 years agoI'd be interested in how you get on. I bought an Arkose earlier this year - great bike, but the 37c tyres (WTB Riddlers) are a touch narrow for rocky off-road use, and I need to run higher pressures than I'd like to avoid pinch flats, which reduces grip. Ideally I'd run 45c and convert to tubeless.
Which Arkose did you get? I've got the Arkose 2 and basically the biggest tyre you can get on the back (with any tread) is a 42. I'm using a Marathon Plus Tour, which has relatively good grip for off road stuff. I've had it on cinder / mud /grass with no real problems.
It's a 2018 Arkose 2. Apparently the newer ones do have a bit more clearance - someone on STW reckons they can fit 45c WTB Riddlers. Maybe those tyres come up narrow.Regulator wrote: ↑5 years agoransos wrote: ↑5 years agoI'd be interested in how you get on. I bought an Arkose earlier this year - great bike, but the 37c tyres (WTB Riddlers) are a touch narrow for rocky off-road use, and I need to run higher pressures than I'd like to avoid pinch flats, which reduces grip. Ideally I'd run 45c and convert to tubeless.
Mine was a 2017 Arkose 2 - it'll be good if the 2018 version has more clearance.
I have a Surly ECR with 3" 29+ tyres (Surly Nards - such a lovely name). It is somewhat slow on the roads and even slower off road. I love the comfort though - I run them at 15psi max and it's like cycling in my favourite armchair.
I think Mr R is being unreasonable there, Reg. Don't forget, it's easier to ask for forgiveness than to ask for permission.
- Sonic Budgie
I'm not surprised, that rear seat looks hideously uncomfortable and the front carrier would be much too small.Regulator wrote: ↑5 years ago
This is what I'm lusting after but Mr R would not be happy:
Trek 1120.
