We've moved to phpBB!
All or most of the content should be here, but it's new software and doesn't yet have all the tweaks it needs. Your account is still here, and password you previously were using should work but if it doesn't, then click the forgotten password button on the login page and take it from there.
http://cpanel82.gzo.com/~cyclingrelated ... ndpassword
If you get completely stuck, then drop me an email by clicking on the envelope at the bottom of the page, and I will get you logged in.
Thanks. Enjoy.
Re: We've moved to phpBB!
Nice!! I've made the transition - I've tried to post a new thread to say it looks good......but apparently, Joan, you'll need to check it before it get posted.
Password didn't work, but eventually I found the change password link (it's not obvious!)
There's also a pre-mod option ticked on the secret squirrel forum.
Sorry folks. Don't quite know what is going on with permissions yet. I will investigate and let you know when it is sorted.
In the meantime, keep posting and I will approve as quick as I can.
Dunckel checking in.
Permissions sorted.
Yippie!! Thanks :-)
There seems to be a stiff limit on the size of uploaded photos. Might be worth an investigation.
And (irony of ironies) there's a double post problem.
So where is the non-obvious change password link?
(your name) in the top RH corner, then user control panel, profile, edit account settings
Got it, thank you!
The control panels are arcane. The user CP is complicated, but until you see the Admin and Moderator ones, you have no idea.
(I need to fix the quote levels)
Fabbers
Post by Fabbers » 7 years ago
Hello playmates!
Fabbers wrote:
Hello playmates!
Welcome @Fabbers! BTW, if I don't see Leonard Rossiter pretty soon, it's going to be hard to recognise you. @Markymark has left very convincing fingerprints every time he has posted.
